richon
No, its a cousin of the Tubescreamer....  same output buffer, almoust same input buffer.... no tone control, Treble cut (passive, not active like BB preamp), bassboost (passive also). Same JRC4558D  ;D
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
tiges_ tendres
My first go at water slide decals.  I dont like water slide decals!
Try a little tenderness.
guitarman89
Quote from: tiges_ tendres on May 26, 2009, 12:32:36 PM
what pedal it is?
built: MXR Dist+,dod250-280,dr boogey,IC buffers,cmos drive,multiface,20W SS pwr amps,phase90,tubescreamer,rat,amzMB,wuly mammoth,dod280,zombie chorus
under constur:60W 3886 amp,jcm800 em
www.myspace.com/guitarmanbll
www.myspace.com/filospinatopunk
tiges_ tendres
Quote from: guitarman89 on May 26, 2009, 02:07:32 PM
what pedal it is?
It's an UglyFace.
free electron
Quote from: frequencycentral on May 24, 2009, 03:38:54 PM
:o OMG! Are you some kind of pedal building android or something? That is such a piece of work.  ;)
I guess i just don't like fuzz boxes ;)
Here's the finished pedal (reverse laser decal, green background)
And here's something much simpler, not very pretty but extremly useful, a low power reactive speaker load emulator i'm using with my small tube amps for silent recording. The basic concept you can find @ aikenamps. I've wound a multitap inductor for the mid/high band impedance rise. The Resonance switch allows to set the resonance peak height. There will be an isolation transformer installed for the LineOut, when i get one...
Slade
Quote from: ocg on May 26, 2009, 09:33:05 AM
Quote from: richon on May 26, 2009, 01:02:35 AM
bbpreamp?
"Ketchup" is a very famous pedal here in Chile :D
Richon pedal's have a great vintage sound!
Greetings, richon!
Guess who am I! ;D
repente
Hi All! Here is my effects  ;D
And here is a big picture of the diy pedals
The next project will be a Zendrive kit  :icon_mrgreen: and probably an artec power supply.
Greetings!
Br4d13y
your graphics are awesome!!!  did you design those?
freedom is the freedom to say 2+2=4
Taylor
Hope you don't ever decide to sell the D+ or TS.  :icon_wink: Cloning circuits is fine, but yoinking trademarked names and logos could land you in some hot water.
Cardboard Tube Samurai
Quote from: Taylor on May 27, 2009, 06:19:39 PM
I was thinking the same thing
repente
Of course!!! I will never sell my pedals; there are like a little treasures for me .
arma61
Quote from: repente on May 28, 2009, 03:19:46 AM
+1!  specially when you draw your own layout, create your own graphics, debug them (if needed, an mostly of them need it!) oh, and the results are  beautiful just like yours are, and the 99.9% in this thread ! They become priceless
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
Kitarist
Quote from: repente on May 27, 2009, 05:54:06 PM
Greetings!
What kind of decals did you use here?
Thanks!!!
repente
Thanks a lot for your comments  ;) , really these pedals, for me, are a "big" treasures because I used a lot of work's hours.
For the decals I used Fasson© Polietillene (plastic label, it looks like a vinyl) printed in digital and after I laminated it with matt plastic.
The result it's a heavy duty label but with a super-soft surface.
P.D.: Sorry for my poor level of english!  :-\  :icon_wink:
nicofx
Etched Twin Tremolo.. the red/green select LED indicate the active channel :)
Tonepad RAT for a friend.
Valoosj
After a few minis, here's a maxi  ;D
You squeezed it into a 1590A - you insane fool!  :icon_mrgreen:
Quote from: Scruffie
Well this... this is just silly... this can't fit in a 1590B... can it? And you're not even using SMD you mad man!
musiclikscreams
Projectile
Quote from: nicofx on May 28, 2009, 12:49:37 PM
What did you use to get such a thick and shiny clearcoat? It looks great! Mind elaborating on your finishing process?
nicofx
#9558
Quote from: Projectile on May 29, 2009, 03:35:54 AM
Several coats (five at least) of Rust-Oleum Hard Hat clearcoat.. wet sanding with 1200-2000 grit in between every coat..
AND.. a whole lot of patience ;)
Renegadrian
The LEDs at the eyes are great!!! Are they to show on/off or are the clipping diodes?! I wish I made mine with the clipping LEDs shown...
