Author Topic: Etched enclosures  (Read 847230 times)
Re: Etched enclosures
« Reply #2380 on: June 12, 2018, 02:45:35 AM »
very cool nathan....came out great man.  8) 8) 8)
cpk313
« Reply #2381 on: July 04, 2018, 02:38:40 PM »
First try at etching, used NaOH, many, many, (MANY) attempts to get the image to adhere on the box and still wasn't 100% happy, the upper left corner was masked fine I just let the etch go a little too long. It took about 20(ish) minutes, thought that it was going to be longer from others' postings, anyhow will know better for next time.
Marcos - Munky
« Reply #2382 on: July 05, 2018, 03:15:31 PM »
10th build of 2018. A friend asked me to build him a pedal called "satan muff", it's an internal joke. Despite the name, the circuit is Joe Davisson's Transistor Obsidian.
DeusM
« Reply #2383 on: July 20, 2018, 10:50:25 AM »
Does any of you guys use clear coat after painting the etched enclosure? Doesn't it peel off?
It's not the amps that kills you. It's the "mojo"
slashandburn
« Reply #2384 on: July 21, 2018, 07:25:41 AM »
I'll second Mat's question. I haven't etched a box for ages now but looking back over my earlier efforts, the boxes with a lot of bare polished metal on display suffered from this "peeling" or flaking that Mat describes.
My reverse etches on the other hand (with more etched and painted surface area than bare polished metal) have held up really well.
I get that the clear coat needs something to grip and that aluminium polished up to 2500 grit isn't really the ideal painting surface, which would explain why my reverse etches and painted boxes hold up really well. There must be something we're missing here, surely you don't all just leave your beautiful etches naked?
Marcos - Munky
« Reply #2385 on: July 21, 2018, 10:55:08 AM »
I just leave them naked, although mine aren't beautiful :icon_lol:. A friend who works painting cars did a clear coat on one of my boxes about 2 years ago and everything's fine until now. Don't know the method he used.
italianguy63
« Reply #2386 on: July 21, 2018, 03:33:53 PM »
+1
I just leave mine naked too.  I figure they will get scuffed up and chipped.  Leaving them naked makes them easy to clean up with a piece of steel wool!
Your buddy probably used automotive clear coat-- a lot tougher and sticks better than shelf-bought spray bombs!!
MC
slashandburn
« Reply #2387 on: July 21, 2018, 05:27:21 PM »
Good to know! I'm attempting my first enclosure etch in about 2 years so hopefully I'll finally have something else to share on this thread. I might leave it au-naturale this time and see how ot stands the test of time.
italianguy63
« Reply #2388 on: July 21, 2018, 05:30:30 PM »
DeusM
« Reply #2389 on: July 23, 2018, 06:00:14 PM »
And what caustic soda do you use? Here in my country it's nos allowed to buy it without a permsiom >:(. I can only get one liquid with 40% or so, or some pearls with around 28% of concentration. Can I still grt good results? I cant't even buy acetone to clean the pedals >:(. Sory. I know this is not the place to ask questions but I'm trying to get good results like the ones I see in you pictures.
« Last Edit: July 23, 2018, 06:02:48 PM by DeusM »
italianguy63
« Reply #2390 on: July 23, 2018, 06:07:08 PM »
You can also use acid.  (I do).  "Pool supply" acid called muriatic acid (hydrochloric acid) can be used too...
MC
DeusM
« Reply #2391 on: July 23, 2018, 06:58:03 PM »
MC
The problem I think is that it starts to loose efectiveness. You have to sumerge it. Seems more complicated for me.
« Last Edit: July 23, 2018, 07:13:32 PM by DeusM »
italianguy63
« Reply #2392 on: July 23, 2018, 07:17:12 PM »
MC
Sort of... you "dip" it... I just mask off the enclosure with blue masking tape (the sides).  Takes about 2 1/2 minutes.. I dip it 30 seconds at a time, then rinse, and clean... repeat...
italianguy63
« Reply #2393 on: July 23, 2018, 07:22:26 PM »
I use a mixture of 1:1:1
Acid, water, 40% hydrogen peroxide
The peroxide comes from the beauty supply house (girls use it to bleach their hair).
If you can't get the peroxide, you can go it without it.  Approximately 50/50 I would think.  Anyway.. if you are interested, I know there are other posts in the forum discussing it.  I was just letting you know there is an easy alternative to caustic soda.
MC
DeusM
« Reply #2394 on: July 23, 2018, 10:52:56 PM »
I'll try that Mark. I read it works good to and leaves a well defined etch. My question is if it's pool water why the reaction with the water? I know it's hydrogen peroxide but I read some guy just uses water. Its the same as HCL right?
diffeq
« Reply #2395 on: July 24, 2018, 03:53:33 AM »
HCl == hydrochloric acid. Hydrogen peroxide == H2O2.
I might be wrong, but the main etchant is HCl, while H2O2 just burns reaction products off the surface so that aluminium chloride doesn't create crust on it. If that's the case, you can do without peroxide, just won't be as effective.
Wear gloves, work outside. This solution sounds like perfect mix to destroy your skin/clothes/carpet.
(funnily enough, regular water is hydrogen monoxide, H2O. With time, peroxide breaks into water and oxygen, loosing it's punch)
thermionix
  • Guest
« Reply #2396 on: July 24, 2018, 04:55:46 AM »
Dihydrogen monoxide.  Scary stuff!
DeusM
« Reply #2397 on: July 24, 2018, 01:46:43 PM »
Yes. So the solution is HCL plus H2H2 right? I have some ferric but its lossing its punch. I read that this solutoon works for a long time and its not that bad for the enviroment. Im
« Reply #2398 on: July 29, 2018, 07:53:58 AM »
heads up UK sanding guys...
i discovered some great cheap sturdy long lasting sanding paper from B&Q.
a 5 metre roll of 'oakey' abrasive paper   now named ' norton expert'
grade 60.  rips the top surface off the enclosure really easily...and gets it properly flat (using a block)
i used the same piece in a block to do 6 x 1590BB enclosure tops, and it still looks as good as new
no clogging, and use dry too.... 8.50  for 5 metres. grab some...
i was using single sheet, crappy stuff, and it was hard work, this stuff is a breeze...
and gets that brushed look very nicely...and will take toner easily too.
no more single sheet crap for me....  :)
stallik
« Reply #2399 on: July 29, 2018, 10:25:54 AM »
Green one yeh?
