Show me your 1590A enclosures/pedals...
Started by andrew_k, January 29, 2008, 09:42:28 PM
Hey!  Stop already!  These are just too relentlessly good.   :D
Groovenut
You've got to love obsolete technology.....
Groovenut
#2184
Latest build, trying out some new knobs. These are 5/8" diameter, slightly smaller than the 3/4" I usually use.
LPD CJOD (Clay Jones Over Drive)
Plus a quick demo vid
pickdropper
I think those knobs look MUCH better on that size build.  The proportions look good.
Very nice build.
Groovenut
Quote from: pickdropper on December 16, 2015, 01:12:07 PM
Very nice build.
Thank you!
I agree though I'm still on the fence about the tone knob being the same size as the other two.
The other thing about these particular knobs is the set screw is very close to the bottom edge and without spacers on the pots, leave the knob high off the surface.
italianguy63
To fill the gap when using Davies 1500 which sit too high as well, i used 7/16" fiber washer. Needed to file  the hole bigger to fit over the pot nut but does hide the gap.
Think they'd take paint fine if you need to match to the knob or enclosure.
dave
Groovenut
stallik
Great idea Dave. Try O rings if you want to increase the friction and prevent the knobs turning accidentally.
felt I'd add: "I add felt". to the knob bottoms, often in contrast colour.
Quote from: duck_arse on December 17, 2015, 09:50:08 AM
That's what i'd done in the past but couldn't find the sheet of felt, searched around for another solution and found the washers would work with a bit of adaptation.
pickdropper
I usually file down the pots if I want the knobs to mount lower.  This only works if the set screw is high enough, which doesn't sound like the case here.
Quote from: davent on December 17, 2015, 02:43:39 PM
You can get felt circles with adhesive backing that are used as feet for furniture and smaller items like jewel boxes.
Groovenut
Usually I machine a small amount from the inside of the hole so they slip nicely over the retaining nut, but these new pots have a the set screw very close to the bottom of the knob and wont allow this.
MarcoB
Hi! This is my first post and this is my 1590A...
My first pedal effect.
My first PCB.
My first decal.
My first!
Is a simple SHO but something had to start!
bloxstompboxes
Cozybuilder
Tidy, well thought out, great job. Welcome aboard.
Quote from: bloxstompboxes on December 23, 2015, 02:13:07 PM
Good sho and good job!
Reading that made me want to say "Jolly good SHO." I can't find anyone at home that thinks I'm as hilarious as I think I am. :P
